did a couple of minor upgrades.
Bullett point 3 point mount
NH Overland auxiliary battery box.
Does it seem pretty stout in terms of holding a battery? I've had this in my cart for about a week but this is the first one that I have seen installed so any feedback on the good or the bad would be much appreciated. Guessing you left the BCDC mount off for now?
It has a minimal amount of what i call vibration movement, nothing that i will concern myself about, if my truck rolls on its roof the battery wont come out. im attaching my own battery isolator to the bcdc mount then i will install it. the fabrication is very nice.
You talked me into it. Ordered one last night.
If it’s not. I just put one in last week. Was able to reuse some of my Ram Mounts parts. Seems like a quality mount.
Cool, and thanks for the pic! I was curious how high it sat, from the website it seems it would sit up higher than the “standard” mount.
I have 2 different bullet point mounts, the one i have now is the newest ram release. both have been solid mounts.
Do you have a build thread? I'd like to follow along but not sure if I should follow this thread or antother?
The Bulletpoint Mounts are awesome. I bought one of their mounts for my GMRS mic mount and it works great.
What isolator are you going with? I believe our trucks require a "smart" isolator because of the variable alternator. I've only just started researching running a second battery.
Thanks for sharing!
Thanks for sharing!
Im using 150amp battery doctor, wirthco.com.
Its designed for newer vehicles.
Sent from my SM-N986U using Tapatalk
Thanks for the info! I just ordered the aux battery bracket.
No issue running the 150amp isolator with our 220 amp alternator? I doubt the battery sees 220 amps.
Edit: Actually looks like the PW comes standard with a 180 amp alternator.
How does the Bullet Point mount attach to the dash? Is it with bolts/screws or double sided tape (or both)?
