delete
ramblinChet
Drinks Alone
delete
It's probably made by Curt and is available on Amazon for $60. Looks identical right down to the shrink tubing on the T end; except for maybe the 7-pin bed plug. I even found one online dealer that shows an image of the identical Curt plug instead of the Pollock branded one. https://www.factorychryslerparts.co...-and-plugs-into-vehic/8675106/82212195AB.html
1 hour. simple install. 'toughest' part is having a drill bit and mental fortittude<G> to drill a hole through your nice new truck bed and getting under neath and up into that section near the wheel well. .
but then its a simple routing it down, zip tying it up, and connecting existing into harness. level 2 install.
That's for the bed 120V option.
index.php
I drilled into the bed side to mount an air gauge for my compressor. It was not difficult at all, just make sure you spot your location from the backside of that panel.
Has anyone installed the Mopar Fifth Wheel / Gooseneck Wiring Harness (82212195AB)?
It looks like there is already a cut out square with a plastic filler in the bed on the drivers side just behind the rear wheel where the plug could be mounted. Your thoughts?
Hello, I am in the process of doing the exact same thing and was wondering how your install went and how you completed it. I have already purchased the connector 68014986AB and the wiring harness 68398007AA, and the cover plate 68453200AA. I am installing the B&W turnover ball and Companion Slider hitch in my 2021 Ram 2500 and am at a stopping point trying to figure out the wiring issue. Thanks in advance for any help on this and I appreciated all the part numbers in this thread as well.
