AZOILBURNER
Hi all,
I did some searching to make sure I'm not repeating another post, and given that Ram is telling my dealer that they've never seen this problem before, I'm confident that I'm in the clear.
I need some help, as the dealer seems lost and is working directly with Ram on this.
Truck Details:
2022 3500 Long Horn CCLB HO/AISIN, MAX Tow, Heated seats and wheel, digital dash, 8.4" display, Plow Prep. Let me know if I'm missing pertinent details and I'll update the description.
Took delivery Early Dec 2022, Put ~4000mi on the truck and in mid-March had this problem.
The Story:
16 Mar 2023, started the truck and warmed it up. No unusually cold or severe weather to note. Drove roughly a mile and stopped at a light. Suddenly, with no warning, no dash lights, no roughness or symptoms at all, and with the truck still in gear, the engine cuts off. I try to restart, but get a no-crank, no-start. The dash and radio remained powered through all of this, I could use the ignition button to shut the truck off, and attempt restart. On the first re-start attempt, I got an interesting message from the auto leveling system that it was leveling the truck, but that quickly went away. Now, when I attempt to start the truck all I get is the normal dash startup, it says it is going through a grid heater cycle, and when I press to start, the ignition switches to run, but no crank and no start. It didn't even throw any codes.
I put a volt meter on the truck and it correlated with the in-dash volt meter, with systems on the batteries were showing low 12.2-4'ish and draining quickly. Charged the batteries overnight, and still nothing.
The dealer has had my truck since 17 Mar, they replaced a BCM and it did not fix the problem. Now several weeks into this, the dealer is telling me that the tech is troubleshooting other modules while on a direct line to Ram.
Anyone have any insight into this? I don't have the truck so I can't make sure that they're working through easy stuff first, and checking grounds, and making sure everything is tight underneath. I went over the whole truck when I took delivery and after I got it home. Nothing seemed out of sorts.
Many thanks in advance!
Truck Details:
The Story:
