Incase 440A was not enough lol
Yeah, exactly what I was thinking. Seems more like marketing than a realistic need.
I mean, they offer a pair of 220s on the Cummins when the Hemi got a 220 and a 160 as the high option. They apparently thought someone needed more. Probably ambulance builders.Yeah, exactly what I was thinking. Seems more like marketing than a realistic need.
With 2 alternators you are in good shapeRAM_GA Unless I'm way off on my electric needs under normal I expect to be well equipped to handle the extra amps. M reasoning is that my HO Cummins came with just one alternator, with the option of a 2nd one when ordered. I wanted to make sure I had enough for whatever I threw at it in the future. I wish I would have ordered the aux switches, but I didn't know better at the time. Live and learn.
Thanks,
Larry
Yeah, I always figured it was some kind of packaging issue, but there seems to be space when I look. Maybe it’s some interference issue and the new alternators are a different shape, or maybe it’s just so they can say “look, you need the diesel for ‘real’ heavy duty use!”I always figured the second alternator on the Hemi being a 160 was a limitation of either the engine or space. The ‘25 Hemi duals output 400A.
Even with 440A the HAPP is only 300A. I wonder if that’s higher on the ‘25’s.
Just to add a bit of additional information to this discussion - temperature and RPM each have an impact on alternator output. For reference, if I am cruising along at 1700 RPM and it's 200° F under the hood, my 380-amp system is only able to deliver 171 amps. You know me, I like to run my mechanical or electrical systems with significant headroom so out of those 171 available amps, I would target using around 50% (86 amps), certainly not more than 75% (128 amps).
Here are the charts for the alternators in my 6.4L HEMI equipped 2021 Tradesman:
Primary:
Secondary:
That’s alternator rpms, not engine rpms.
At 1700 engine rpms the primary is turning 4,930 and the secondary 4,624. That gives you over 297A available, not 171A, at 200°F.
Thanks, but how did you get that engine rpm #?That’s alternator rpms, not engine rpms.
I was gonna say the same thing lol. Plus I believe the OEM alt is 180A on the 19+ where that chart says 160AThat’s alternator rpms, not engine rpms.
The pulley ratios are published on the amperage chart. 1700x2.90=4,930.Thanks, but how did you get that engine rpm #?
The 160A chart is for the 6.4 secondary alternator.I was gonna say the same thing lol. Plus I believe the OEM alt is 180A on the 19+ where that chart says 160A
Thanks it makes sense now. I missed the ratio on the chart.The pulley ratios are published on the amperage chart. 1700x2.90=4,930.
