Dash Oil Pressure Gauge seems weird
jeepkevin
I have 500 miles on my 21' 2500 6.4 and just noticed that the oil and volt gauge aren't needles, they seem to be digital markers. When truck is off, you don't see the needles, when you start the needles just seem to appear at appx the half way mark. The oil needle sits half way at idle and jumps up a bit with any throttle. The digital pressure gauge summary fluctuates with rpm but needle is either half or up a bit. I'm guessing this is normal? Never had digital needles before.
Depending on what screen you have you should be able to customize it to get actual numbers. Volt meter should read around 14.2 to 14.4 volts when running. Oil pressure should be higher when you first start and as the oil heats up it should lower a bit. It should also get higher pressures under more acceleration. As long as you have oil pressure that's the important part.
It's all computer generated from ECM data anyway. Can't say on the Hemi, but the Cummins doesn't even have a true oil pressure sensor anywhere in the block.
Interesting.... i have not looked but im sure they would have a sender on them all my older cummins had a pressure sender
Edit, after a quick part search i have found a listing for an oil pressure sender.....
Last night I looked at the volt and oil pressure gauge and you can see how they are segmented such that the needles have positions they light up at. They don't have a clean sweep, just light up positions.
Perhaps I'm mistaking it for the oil temp sensor... I know I saw one of them didn't really exist.
I just bought a 2022 3500 last night. This morning I thought those two gauges had stopped working and was about to call the stealership about it. The markers are difficult to see when the sun shines on them. Google lead me to this post. Thank you for sharing it.
