Dash Lights Blinking Intermittent
swat645
2021 Ram 3500 HO Longhorn Limited. Dash lights (instrument cluster/radio) are blinking intermittently. Mostly occurs when truck has set outside in the heat. They blink intermittently both when driving and sitting still. Scheduled for a service appt. and dealer says "it may just be a software issue." Anyone else had this occur and what was the outcome? Thanks
Check to see that all your fuses in the PDC under the hood are seated fully.
I certainly will. Had the truck in the shop and the tech said there were no "codes," and said something about each cluster having a separate ground which would eliminate all blinking at the same time. He said he wanted to send a starlink(?) query in to Ram and that he would need the truck for the entire day so it was available when they call. SO back to the shop it goes next week. Fortunately the blinking is very intermittent and does not affect anything else otherwise. I do appreciate the troubleshooting advice.
