Custom harness(upper console swap)
asub2009
I have a 2022 ram 2500 I swapped my upper console out for a premium because it has the rear window control that I’m planning on getting installed soon
I am pretty sure I need a custom harness made because I can’t turn light on with the switch but it comes on when door opens. See attachment
As you can see I unplugged the one installed harness and plugged my factory into it to get it to work because I don’t harness for the grey plug
This almost certainly indicates that you're missing some wires in the console harness. The fact that the light comes on when the door opens means that the power controlled by the BCM is working, but the console button can't turn it on because the control wire isn't present in the gray connector on your truck.
