savaytse66
I will be installing a PowertraxPRO tonneau cover this weekend, and had a question about hooking up this, or any powered accessory. This cover is meant to connect directly to the positive and negative terminals of the battery. Since we have the Aux switches, I thought it might be cleaner to hook it up to the Aux Power Distribution Center under the hood, that way I'd have an extra level of security with the ability to shut off power to the cover if I wanted to.
When hooking this up, am I correct in thinking that I can just hook up the red positive to the Aux Connector, then connect the black negative to a ground? Or alternatively, connect the black to port 3 of the light gray Aux Connector, which is labeled as "Ground Z907"?
Ideally, if someone knows of a way to actually OPERATE the cover from the Aux switches, that would be great! I'm sure it's possible, just not officially supported by Retrax since they provide wireless Key Fobs.
Thanks
Thanks
