Briarsmoke
My 2022 tradesman came with the LT275/70R18E OWL On/Off-Road Tires. The stamp on the tires reads max 60 psi. They were aired at 75 rear 65 front from the dealer. When I aired them down to 50 all around (was looking to soften the ride a little, not towing) the tpms light came on and got a message on the dash to inflate rear tires to 65 psi. The tires are rated for 60 max but the truck computer wants them at 65 minimum. I assume this is because the computer thinks there are different tires on the truck, but these are the factory installed tires that come with the truck (snow chief and off road packages). Is this a programming error that the dealer can/should fix so the tpms warning is changed to accomodate the tires that came with the packages installed? I’m not going to be hauling or towing anything heavy, and will likely be swapping the tires out for 33” KO2’s eventually, won’t need to running 65-75 psi.
