Lumpskie
Hey guys,
When I turn on my (2020 Laramie trim) truck, my climate control always comes up set to 72 degrees with the fan speed turned all the way down. It used to stay where I left it. The change is annoying but I have noticed something even more annoying. Occasionally, when I start the truck, my climate control will also not react to my use inputs... so it will stay at 72 degrees with the fan all the way down, while it is in the mid 90s outside. I'll drive the truck in the heat, park it an start it the next day to find it works fine... then it will do it again. (It never happened before it got hot out) When I press the screen (8.4") for climate control or use the knobs, I can see the screen react to my user inputs, but the fan speed, fan position and the temperature do not mechanically adjust. Have any of you experienced this before?
