Thank you so much for your help I have been trying to look this up for some time with no luck. Do you know what the liquid electric tape is called I didn’t know they made such a thing, the chewing was just pretty much the plastic around the wire. I’m use to the old school plug wires etc. You made my day when you answered my question! Thanks again so much
The stuff @Poolmonkey posted is good stuff.Also another question. Could this be causing my gas cap/ engine light to come on, truck is running great but I keep getting a code P0455 Evap system large leak. Thanks again for your assistance on this
Thank you I will check it outAlways had old school Starbright on hand but this is a bit cheaper, at least on Zon…I don’t have my specs, does it say gender-bender? -))))
Just to give you a update, weather turned really cold and truck is to big to get into my garage. Stopped at my local shop where I go for things I don’t want to do and there going to repair it Tuesday for a cost of about $50. Thanks again for your help.The stuff @Poolmonkey posted is good stuff.
And no those wires being chewed won’t cause an Evap code. You might have just left the gas cap loose so I’d clear the code, tighten the cap and see if it comes back. If not then life is good.
And no problem for the help! Glad to assist
