Changes to BCM from Dealer Flash
01Time
Central Texas Hill Country
I recently had my truck in for an electrical issue with my blind spot monitoring. Thankfully it seems to be repaired after they overlaid the rear wiring to the BSM modules in the taillights. But as I was remaking the changes with AlfaOBD for the options I have installed, I came across a few changes that were made by the dealer. I'm mostly curious of the effect of the first change listed about the transfer case ratio. I haven't used 4WD since I got the truck back and now that I know something was changed, I'm hesitant to try it without first understanding what this change is. Can someone translate this for me?
AS DELIVERED FROM FACTORYNEW SETTING FROM DEALER FLASH
VehConfig 4: Transfer Case High Ratio (0-16.382): 1.000VehConfig 4: Transfer Case High Ratio (0-16.382): 3.304
-Not Previously Present-CBC Config I/O Usage: Connector F Pin 5: Fog Lamp Rear Left/High Beam Shutter: Left Rear Fog Lamp
Cust.Prog.Features: Headlamp Delay Time (0-254 sec): 0.000 secCust.Prog.Features: Headlamp Delay Time (0-254 sec): 30.000 sec
