Change headlights to LED.
Jimmyj321
Need some advice and help. I changed my rear lights to LED. No major problem. There was some confusion on the bulb numbers but I finally figured it out. I have a 2019 Big Horn Cummins. Do I have projector headlights? I look at them and there is a small rectangular looking plastic gizmo just ahead of the lens. From what I understand this should mean I have projectors. Can they be changed to LED's. Looking on line I am assuming I can. My local body shop told me he would change them for $65.00 labor. Does anyone have experience with any brand of CanBus connectors that they would recommend ? I see various customer ratings that rate most average and the rest really bad?
If you have halogens you have the base headlights not projectors you are probably seeing the shield over the bulb. Big horns do not get projectors they only get reflector leds or halogens
Check out Headlight Revolution, they have everything you would need along with the install videos. That's where I got all my halogen to LED bulbs,
Went to “Headlight Experts” and got bulbs. Lights came with CanBus bilt into harness. Simple unplug and plug in new bulbs. On my truck there is a big rubber cover you remove and reach in and change bulbs. Had to remove air filter box to change passenger side. Not too difficult. I have big hands and it was tight.
