CCV filter cover
2021Leveled
Does any happen to know what the torque spec is for the crank case filter cover?
When I did mine I used this: The 2020 RAM 3500 6.7L Cummins High Output Turbo Diesel engine has a crankcase cover torque specification of 18 ft-lbs (25 Nm) for the 10mm bolts and 44 ft-lbs (60 Nm) for the 15mm bolts. The 8mm bolts for the "batwing" cover on the CCV should be torqued to 89 in-lbs (10 Nm). Additionally, the valve cover should be torqued to 20 Nm (15 ft-lbs), while the rocker housing requires 80 Nm (60 ft-lbs).
Hope this helps.
