Cat Scale question - with/without trailer
b1lanc
Sorry, think I posted in wrong sub-forum.
Different scales read slightly different, and placement on the scale makes a difference too.
Most the time when I scale my front, rear, and both axles the front+rear is a different number than the entire vehicle.
Thanks. Same scale at the local Pilot. Can't guarantee I was set the same place each time though.
As
Most the time when I scale my front, rear, and both axles the front+rear is a different number than the entire vehicle.ask scale operator where to place your axles if the pad isn't marked for tractor axles
Having scaled trucks hundreds of times just make sure you are centered on the scale . Accurate within a 100 lbs or they will pay the over weight ticket !:D
