The loop connects between the head unit and the factory harness and places the processor and amp 10 feet from it. The amp will sit under the driver seat on a cooling rack so I have access to adjust it.So does that just connect between your head unit and the output wiring to the speakers to pick up signal?
I have the 8.4 non-factory amped. The cable wired to the processor/amp was custom made by LLJCustoms.com. I am installing Focal Access 690 AC in rear doors. Front door and dash get Focal Access 165 YE components with adjustable crossover. The sub is a Kicker Hidaway 8 inch square with 150 watt amp.We want to see more install pics! Which stereo do you have and was this custom made or how exactly did you order it?
Probably going to have to put 1/2" spacers to raise the rear seats. That way I can have an air gap under the both of them. With all the extra work I am having to do, this may be the last upgrade I do. Every new truck I have bought, it is just getting more difficult to make changes. Admittedly I have just under a $1000 invested in this one. It will definitely sound better than the factory upgrade for the same amount. Maybe it's the challenge that make me do it......back to the shed, more decisions to rattle around in my brain.
