Can you upgrade auto level suspension?
kwick66
Auto level rear suspension.
Is it possible to switch out the stock tank and/or compressor?
I’ve always ran an onboard air system with a Viar compressor and 7gallon tank for airing up tires, train horns, etc.
I’d prefer to have the fit and finish of the oem system, but the convenience of a larger tank and compressor.
I would guess fooling with the OEM setup would cause trouble. Better to do Airlift, Firestone, or PacBrake bags, and the compressor/tank of your choice. You would need to install a control valve setup to control the bags separately from the reservoir.
I've got a call into Thuren Fab. Planning to as if the level extensions will work on the new trucks.
