Can you identify those connectors?
kristof
While I was working on my remote starter I noticed those connectors. They are not connected to anything. One connector is located near the BCM and have thick wires plugged in. Like red , pink and purple. The other connector is located behind the radio frame. Do you know what those are for?
I'd have to check my notes, but pretty sure the grey connector is the AUX pass-thru wiring. There's a jumper that comes in the wiring kit, those bring the IGN and BAT to the rear frame and bring an extra wire in that you can jump from one of the AUX connectors under the hood back into the cab.
I think the details are in the dash camera thread if you can find that one.
It's D2621A in this diagram unless I'm mistaken. The crayons are my notes. I used it to bring AUX6 G425 into my cab for my dash camera BD 2WD Low range Kit, IGN and BAT for my dash cam.
It's D2621A in this diagram unless I'm mistaken. The crayons are my notes. I used it to bring AUX6 G425 into my cab for my dash camera.
This is sweet cause I want to connect my dash cam and radar detector also. I don't like to have bunch of cables hanging from my mirror or the lighter socket
Yes, if you have the Aux switch setup, you can bring IGN, BAT, and jump any Aux into the cab.
I misspoke.
I needed AUX (switched) for my 2WD low range kit, IGN and BAT were used for my dash cam (needs battery for motion/bump recording). Just ran those wires inside the headliner and down inside the A-pillar.
I misspoke.
Yes I have all the switches in place. My truck came with what is called a "snow chief group".
