Adamlollar
Just got my 2022 Ram delivered. I should of gotten the bed outlets. Does anybody know how to get that added?
Not sure it is worth the effort. Good for charging a battery package but not much else. The ignition goes off after a while and I have to keep turning on the ignition to get a full charge. If you are running down the road long enough I suppose eventually it would fully charge the pack. Pretty useless in my opinion.Just got my 2022 Ram delivered. I should of gotten the bed outlets. Does anybody know how to get that added?
Just trying to scramble some eggs on hunts and fishing trips. LolNot sure it is worth the effort. Good for charging a battery package but not much else. The ignition goes off after a while and I have to keep turning on the ignition to get a full charge. If you are running down the road long enough I suppose eventually it would fully charge the pack. Pretty useless in my opinion.
Nope. Not even close the power to cook with.Just trying to scramble some eggs on hunts and fishing trips. Lol
recommend a simple propane stove. Will collapse and be easier to store than whatever hotplate you were planning to use with the outlet. Then you can take the hot element away from your truck too. I've had a coleman 2-burner for years that I picked up for about $20. Way easier and cheaper than trying to hook up an aftermarket 110V system!Just trying to scramble some eggs on hunts and fishing trips. Lol
Just used my 50 year old Coleman 2 burner stove Labor Day weekend. Great stove that does the job when you want something quick and easy. Stove was my grandmothers.recommend a simple propane stove. Will collapse and be easier to store than whatever hotplate you were planning to use with the outlet. Then you can take the hot element away from your truck too. I've had a coleman 2-burner for years that I picked up for about $20. Way easier and cheaper than trying to hook up an aftermarket 110V system!
