Camper and Trailer Lights Flicker
aogmitch
After loading my camper the first time, I noticed the lights were flickering, as in going bright to dim. Never cut off, but fading in and out. Never did that with the prior two trucks that I have hauled the camper on. Then I realized that towing a trailer, with or without the camper, the trailer lights do the same fading in and out.
Anyone else have this issue? Is it because the truck is all LED lighting, and the camper and trailers are standard bulbs?
It should not matter, I see you have a 2025 so that could be the an issue with the 2025, they have been having some unique electrical gremlins. Friend of mine has a 2025 and his 5th wheel lights are not LED and does not have that issue.
I would maybe put some dielectric grease on the 7 Pin and see if that helps.
