jared43758
With the cold weather how long do the diesel trucks take for there cab to warm up. They claim to have supplemental heaters on the diesels.
I haven’t had enough sitting cold starts yet to have accurate answer. On a couple starts after sitting overnight it worked quickly,started melting snow off of the windshield with in a minute or two. I think this truck has the best heater I have ever had including my 16 Rebel and other gas jobs. Way better than our 2012 diesel that I make the wife drive to workWith the cold weather how long do the diesel trucks take for there cab to warm up. They claim to have supplemental heaters on the diesels.
It's pretty quick, especially if the block heater has been plugged in for a couple or three hrs. As regards the supplemental heating, the following details are courtesy troverman over at cumminsforum:
"The heater is located in the heater box downstream of the heater core. It consists of three 400W resistors, which translates to 100 amps at 12 volts.
Operation is automatic, based upon the following conditions being met:
-Engine must be running at 700RPM or greater
-Outside temp is below 68F
-Coolant temp is below 158F
-Battery voltage must not fall below 12.6
This supplemental heater can be had on vehicles with automatic or manual climate controls. However, the workshop manual lists it as an option rather than standard equipment. Check your fuses / relays under the hood. The manual calls it a "Positive Temperature Coefficient" heater, or PTC."
Look in the left rear corner (aft of the battery) of the engine compartment. If you have the PTC there will be an auxiliary PDC (fuse box) in that location that contains three relays and three 50A cartridge style fuses.So I need to check the fuse box to see if I have it?
