Bypass cable
GBB
Instruction say to pull two wires off the back of the OBD and replace with the two on bypass cable…I’m wondering what the two I pull off the OBD control?
Sounds like the wrong kind of bypass.
The correct style bypass cable plugs into the CANBUS blocks behind the headlight switch.
Plug side goes to CanBus …spade side plugs into OBD
I've seen that style. I didn't like the idea of messing with the OBDII plug. Instead I went with a Kaodtech bypass cable. You plug it into the security module (2 plugs instead of 1), and then plug into the OBDII like you're connecting a scanner/programmer. Plug in your tool to the other end of the OBDII and you're good to go.
Granted, this way was $50 instead of $25, but I can only imagine the cost of replacing the OBDII plug if I screwed it up. Worth the extra $25 to me, but if you're comfortable with such things the other style should work well enough.
