That's a very high tech answer my friend .... any chance you could dumb it down for me?yup. non deleted trucks make a few clunck zippy whurr noises.
Fixed it for ya lolegr valve cycling. DEF purge. active grill resetting.
The fan is driven by the engine its not electric it only has an electric clutch so with the engine off the fan is not runningi believe the radiator fan will also motor as required with truck off.
Yup, i misread that warning.The fan is driven by the engine its not electric it only has an electric clutch so with the engine off the fan is not running
Thank you very much sir. Exactly what I was looking for. I find all of the diesel-specific tech fascinating.egr valve cycling. dpf purge. active grill resetting.
