Build-in Resistor Front Turning Signal for Reflector LED headlight
diablo82
Does anyone have one of those resistor build-in front turning signal LED bulb that work currently without hyper flash or bulb out warning? I used to have an older set that work but I sold it with the headlight. I tried several set from Amazon but none of them work so far.
Thanks.
They are expensive, but they work. And they are very bright…almost too bright lol. You can see the Amber blinking reflecting off the ground , street signs, cars next to/in front of you. But they certainly let your signal be seen, and match the crisp LED on-off with the rest of the lights on the truck.
Note; when installing them, if they don’t work, flip the bulb 180*. They are polarity specific, but there isn’t a way to know the “right” way except by trial and error.
Is that $156 for a pair (two) or four bulbs?
For some of the bulbs yes @Jimmy07 can confirm if this is right
I tried this with some switchback bulbs and only one of the two on each side would light up. This is after using AlfaOBD. If you(or anyone) know of a brand of good led bulbs that will work correctly after using AlfaOBD, please share.
No clue as i dont really care for switching every bulb to led i have not looked in to it
