Build #2
Wheelz
The Treasure State
Just wrapping up another build on my replacement truck..Doing a single charger rather than another compound setup
-Hamilton Flat tappet conversion with #105 springs
-Xotic Headstuds
- 2G swap from Stainless Diesel S468 5 blade mafia w/dual ball-bearings
- King speed billet valve and timing cover
-Randy's built Aisin transmission. Their "Big Papa" rated up to 850hp.
-Industrial Injections 10mm stroker pump (using OEM sticks)
-Fass 165g external pump with Fleece sure flow pickup
-Banks Ram intack horn
-Mishimoto Intercooler
-BD Diesel Exhaust brake mated to 5" exhaust (yes, they make them for 4.5G trucks so you I can retain the exhaust brake tables when tuning)
maybe mid 600 up to high 700's..since I'm using stock sticks..I'm thinking just in the 600's or so. I originally was going to use 60% overs but that damn snap ring in the aisin grenaded my trans. So my budget went to the new trans instead. Now, I'm just waiting for some parts and then she'll be put on the dyno to fine tune it and we'll see what she puts down.
With all these holiday specials going on, decided to add a S480 and 60 over sticks...can't wait for the piping to be welded up.
Kinda a travesty for the welder since I have to heat wrap his artwork. Unless anyone knows if there's a coating to insulate the hot and down pipe
