F3arl3sslimited
Well I messed up. I thought I remembered how to remove the door panel to plug in the lamp near the door handle, but apparently not. Long story short, I failed to remove the handle trim piece prior to removing the door and I broke off the bottom door handle mounting tab off of the door carrier. It appears that I will need to replace the whole door carrier which apparently has the window regulator integrated into it. Is this my only option? Tried to jbweld it back together with no luck. I thought about making a metal tab for the bottom and riveting it to the remaining portion.
