Anyone tried out this BRExhaust OE Fit exhaust system?
Looks like BRExhaust is owned by Magnaflow so fit and quality should be decent.
Says it’s OEM diameter (3.5”), vs the magnaflow performance that are 4”; but it does seem to replace the large rear muffler with a smaller resonator just before the axle (similar to the magnaflow performance exhaust) so I would expect it to be slightly louder than stock but not much.
Big thing I like about it is it doesn’t have that huge muffler hanging behind the rear axle; and that also should be easier to cut for higher clearance exit (offroad).
Price is fair, $800. It is aluminized steel(like OEM) vs stainless steel
www.magnaflow.com
BRExhaust 2014-2023 Ram Direct-Fit Replacement Exhaust System
BRExhaust Direct-Fit Replacement Exhaust Kit 106-0803 takes the guesswork out of replacing your exhaust system while providing a reliable and high-quality alternative to the OEM exhaust. You will find all of the gaskets and clamps needed to get the job done in the carefully packaged box...
