Hey,
First stretch of time not having driven my 2025 Ram 2500 (5 days or so). Went to start it and it did everything but start....checked the battery and it was under 12v. Jumped it and it cranked over but didn't start. Had to turn off the ignition and back on and then it started...and of course, it threw a CEL.
I charged the battery, cleared the codes and then the truck started and drove normally.
However, something caused the battery to die. The truck was off, locked and keys were not inside the vehicle. I did have something plugged into the 12v socket and I assume that was what caused the drain on the battery.
Last night, I switched the fuse so that the 12v socket is OFF with the ignition off.
I also have a dash cam plugged into the USB port in the center stack. Curious if this stays on for 1 hour or indefinitely after the ignition is off? Last night I shut the vehicle off, 12v socket was off, dash cam plugged into USB...by the time I checked the battery voltage today it had gone from something like 12.5-12.7 down to under 12.3v.
What gives? All research I have done leads to inconclusive or inconsistent results/ fixes.
