Yep.@jetrinka is concerned about his lines and the weather because he runs the with the valve cores removed, so they intake and expel air with every bump.
They are fine exposed if you aren’t running them with the valve core removed when empty.
I thought of that but since I wanted to run without the valve cores in 98 percent of the time I wanted them shielded from road grime and water. It sucked getting them mounted in the Ramboxes but I like them thereWith a little enginuity, you can run the schrader valves as your license plate mounting “studs”.
Makes filling a breeze, and it’s super clean too.
Sorry for not clarifying. I can look up the part number later but Airlift has a lot of bags that has internal bump stops. The directions still say to maintain 5 PSI in them but I don’t see a point.Thanks! The airlift bags that replace your bumps or the ones that go inside the springs? And what are the daystar cradles?
If you have the time to post a link I would love to take a look at it. Sounds like an interesting conceptSorry for not clarifying. I can look up the part number later but Airlift has a lot of bags that has internal bump stops. The directions still say to maintain 5 PSI in them but I don’t see a point.
Daystar Cradles are more something PW owners get worrying about suspension travel. Normally the bag has its own perch secured to the axle tube. The Daystar cradle eliminates this and gives the bottom of the bag something to rest on without limiting axle articulation off road. In a truck or Jeep where excessive articulation is possible you could limit this with a bag tied to both the axle and frame or worse tear the bag.
dieselpowerproducts.com
