Blind Spot notification does not chime
phatboy64
I have a 2023 Limited and so far I have found two things that don't work as described. Anyone else having the same issue as #1 below? and has anyone figured out how to fix the second issue below?
1. When I set the "Blind Spot Alert" to "light and chime" it doesn't work. I only get the light in the side view mirror and no chime
2. "Turn Signal Activated Blind Spot View" This has been documented in another thread but from what I can tell has not been resolved but displaying the blind spot camera when the blinker is on doesn't work either.
For number one, there will be no chime until you use the turn signal when the mirror indicator light is on. Have you confirmed that there is no chime when using the turn signal, or were you thinking that it would chime whenever the mirror indicator light comes on?
For number two, the more people that document this issue with their dealer, the better to get a star case moving along for a radio update.
Thanks. Yes I was expecting the chime whenever a car was in the blind spot range.
I have an appointment with my dealer later this month and will bring up the second issue.
