Bilstein shocks part #
Braggster
Good morning all. First post ever
Have a 2020 Ram 3500 crew cab with 6.4. Just installed a 2.5 level up front and 1 inch block in rear. Does anyone that changed out stock shocks to bilsteins know what the bilstein shock part number was they ordered for front and rear?
Cant find anyone that sells in sets either (front and rear) sold together. Only want to install bilsteins as I have had them before on previous trucks. Appreciate any help!
I added the 1.75 inch level to front and left rear at stock height. Orded the below and the truck rides way better then it did stock. Im also running 35x 22.5x 20. Nitto Ridge Grapplers. I hope this helps. The customer service at billsteinlifts.com was excellent.
For 2020 Ram 2500 Limited 4WD ETL 6.7L L, Front:Coil Rear:Coil
Front
https://www.bilsteinlifts.com/shop/...-2-5-front-shocks-ram-2500-2014-2017-4wd-gas/
and rear
https://www.bilsteinlifts.com/shop/...-rear-lift-shocks-for-2014-2019-ram-2500-4wd/
Thanks HarleyD1
Also my truck is a 2500 not 3500. Contact these guys they are very responsive and can get you what you need.
HarleyD1
I have a 2019 3500 gas, these are what I used.
Bilstein 5100 front - 24-251747
Bilstein 5100 rear - 33-238555
I used bilsteinlifts as well.
Thanks for helping me out and providing the info Harley and Squatch. I will for sure pull the trigger and buy from bilsteinlifts. I Liked what I saw from the links provided. Thanks again for your time to post those
How are you liking the ride? I had 5100s on my last two trucks. One was great but the last one I was not impressed. What’s your setup?
I just have the zone off-road 2” leveling kit, the factory shocks aren’t designed for any lift, so these are a great replacement shock that is designed for that amount of lift. There was an improvement in ride quality, mainly small bump compliance, but it is certainly nothing to write home about. They don’t look bad either.
