Sorry my truck has the 6.7 cumminsAnyone know if the mopar 50 gallon tank will work for a short bed? Or anyone have reviews on the titan 52 gallon?
Hey when you put in your tank did the DTE work right away?I also have a 50 gallon Titan tank on my Megacab. I measured and I can fit in 8 gallons of fuel after the needle shows full. Once it starts going down I know that I have 42 gallons left. One other thing I noticed with the Titan tank is my fuel gage is more accurate at the low end of the fuel level. Previously with the stock tank I would read empty with the needle on E and could only put in 27 gallons to a 31 gallon tank. Now when I am about a 1/16 I am able to put in 44-45 gallons. I haven't gone past the 1/16 yet though so I do not know how low it will still pickup fuel or not but with 45 gallons of usable fuel I get around 380 miles towing my enclosed trailer at 80 on the freeway or around 5 hours between stops, gets mighty tough on some peoples bladders lol.
I have a 3500 long bed Ram w the 31 gallon tank. I bought the atitank 46 out of the gate. Good for 700 towing at least.77 gallons.I have the Titan tank on my short bed 3500. Fuel gauge shows full until you burn off enough fuel to get back to the 32 gallons, then it is pretty accurate. Easy math for the amount over the regular tank.
Not sure why the manufacturers (all of them on the short beds) put that small of a tank on a truck that when towing may be getting 10-11 mpg.
Its the first thing I'll be doing to mine.My brother installed the Titan and is very happy with it. Say's he should have done it sooner.
My DTE doesn't work right and I don't plan on adjusting it since I have gotten used to how it works now. When I have a full tank not towing it says right around 500 miles but in reality it should say closer to 750 or 800 miles. It stays at that 500 miles for around 100 -130 miles then gradually goes down as the tank empty's. I did try to adjust it when I first put my tank in but the DTE was way off and the fuel gage didn't want to read right so I reverted the BCM setting back to stock. As an FYI I get mid 15's MPG not towing and around 9 MPG towing with my setup, all hand calc.Hey when you put in your tank did the DTE work right away?
