New power wagon owner. Am thinking about swapping out the OEM tire for BFG T/a KO 3 in LT315/70R17/F 128S size. Will this work with no rubbing and importantly will it fit in the spare tire location? This tire is listed as 34.4 inch diameter.
Firstly, Ineos Grenadier - very neat! Had a friend considering those before he decided he wasn't hardcore enough for the (likely) reality of living in such an offroad-specialized vehicle.The BFG HD Terrain is designed for Heavy Duty trucks specifically. For towing, off road use and so on and long life. There is a reason why they are getting nothing but 5 star reviews. I also put the same exact tire on our Ineos Grenadier. Also, a heavy duty, solid axle beast.
This guy againThe OEM glass tires must be swapped out ASAP. Those Wrangler Duratrash are frankly DANGEROUS as they pop so easy. I cannot believe they still roll those things out. I plan to drive my next one straight to discount tire and avoid the dozen flat tires of the first round. The BFG HD terrain 35x12.50 is the best tire for this truck, hands down.
You are the only one i see complaining about this…. They are some of the longest lasting tires for HD trucks. Here were almost exclusively use them for the mines as most other tires get shredded by the gravel and ore, way more chance of getting cut up than your off roading. I usually get 60-65k miles out of a set of duratracs. The mines usually get 30-40k miles and they get abused hard.I have never heard someone getting 10K, let alone 50K out of those. Guessing no off-road use?
Anyone who wants my 2018 PW for 10K below book because lifters and manifold bolts are a hoax on Hemis I will sell it to you asap and drive something else until Stellantis opens the order bobook
Sounds more like major abuse. Possibly thinking “off road” means flooring it through the bush based on his commentsGuess you got a lemon.
76K miles on my '21 PW and no issues.
Nice looking tire those M/T’s are they look like the Dick Cepek mud countrys.Duratracs are very good in the snow IMO. The new Duratracs have been improved with a 3 ply sidewall just like the KO2 or KO3 so the weak sidewall has been addressed. Some tires won't be rated for over 50 psi so your air pressure sensors will be on all the time if you get those with the softer ride. I never had a problem with Duratracs but I did switch out to 315 10 ply with a +19 offset wheel as soon as I got the truck. If you get a wheel with the right offset, around +20 you can usually run up to a 37 inch tire but a 35 inch tire is as big as your can get in the spare tire. I just put on the new Goodyear Boulder MT with a 3 ply sidewall in a LRE. Pretty new tire on the market and so far i like them but they are not 3 peak snow rated. The have a deep aggressive tread and don't make too much noise on the highway.
Did you just join the forum to be grumpy in every thread?Not sure about the snow rating. My experience has been they are exceptional in the snow. That being said, we only had one bad snow storm so far this year, been dry since. But last spring I did some deep stuff, including 3.5' of snow towing a 7K camper. I never got stuck, just had to go back and forth a few times. I also backed up a snow field as far as I could last summer turning around on a trail and was blown away by what it did. I was very concerned about the hard compound on these. I live in a neighborhood with a big hill, and sometimes unplowed roads so its a good test. Not like where we are moving to in Silverton in a few years, but a good test. So far better then other tires I have used. Really hard, so many variables, so not real scientific. I spent 10 days overlanding to Moab and such with the Ineos October. I would say a BFG A/T might be slightly better on extreme stuff like stacks of vertical ledges, but not by much. To me the longer tread life and puncture resistance is worth it. You cannot go wrong with any BFG off road product, but for heavy duty purposes I believe in these HD Terrains. The other thing I noticed is, I really need a tire rotation right now, but they are resisting cupping better then other tires I tried.
Anyone who wants my 2018 PW for 10K below book because lifters and manifold bolts are a hoax on Hemis I will sell it to you asap and drive something else until Stellantis opens the order books. I would be happy with taking the hit. As far as the Dura tracs, if they are not popping, you have not been off road. I live off road, and have a subdivision business off-grid so I deal with tons of flat tires. But if you think those Dura tracs have even any durability or redeeming qualities, you are not working that truck hard.
Its the same story for that guy…. Everything is junk to himDid you just join the forum to be grumpy in every thread?
