Bed outlet wiring question
midntrdr
I was under my new truck and found a connector hanging behind the rear wheel well liner. Looking up with a flashlight it appears to go to the 110 bed outlet. Can anyone look under their truck and post a pic of where that wire is supposed to plug in to? Bought from a dealer 2 states away, and my local dealers are weeks out on appointments. Thank you.
In the second picture, the lower wire is the one that goes to the 115 v plug. Hope this helps.
This is very helpful! Thank you.
Mine didn’t have bed lights so there wasn’t wiring there, but I’ll check if there is an empty harness tucked away in that area.
I found the plug and connected it and now I have a working bed outlet! Thank you. I was able to hold up the picture under the truck and find the wire tucked up out of the way.
You saved me a trip to the dealership which is never a fun experience.
Can you explain, did your truck have an outlet in the bed already that didn't work? What year and trim is your truck?
2023 Laramie 2500. Was installing LED bed lights and when I was under the truck I found the wire from the bed outlet just hanging down behind the wheel liner. I assume it was possibly never connected at the factory.
