Bed Lighting
russ2588
I watched a few youtube videos that said if you buy the bed lights and switch the wiring will be there well it isn’t under mine (22 2500 bighorn) and i found out when i looked for it. I seen in some other forums that for a half ton you can replace the wiring harness (jumper wiring ) but i can’t find it for a 3/4 ton and was hoping someone had done this and might be able to steer me in the right direction.
If refering to the mopar Led lights in the corners of the bed near the taillights then yes if you buy the OE light kit everything is PNP. You just have to use AlfaOBD or similar to active them.. I added them to my 2020 Laramie
Thats what i am referring to annd what i feared. Unfortunately i watched a youtube video of a guy who had the connectors below his truck already which i do not. Unfortunately i bought the lights and switch off ebay but i can’t find the wiring harness to go back to the cab separately (outside of the kit) so i guess ill be buying a kit and have an extra set of lights and switch. thanks
Salvage yard? You might have to spend a little time on the phone to be sure they pull all of the stuff you need. If you have a place nearby that still lets you pull parts it would be even better.
