Bed light Wiring
DirectJH
On the 19-24 models the kit has two wires that connect to different pin areas. On a 2018 it has only one and the ground. Can the 19-24 be wired with just one? If so is it the harness in the engine compartment or under the dash?
Hoping you find an answer. I’ll be following. Which kit are you using? I just bought this set as I found a forum that said it would fit, but I’m concerned it’s not going to work.
Cargo Led Bed Light/Lighting Kit Compatible with RAM 1500 2500 3500 2016 2017 2018 Replace 82214870AB
https://a.co/d/aLB9Tqk
