Woodywoodpecker
I'M NOT YELLING
can anyone with a 2020 2021 3500 dually 2wd with rear auto level factory air suspension give me a bed height measurement bed to ground at tail gate
i have them spec"s but was looking for some real live measurement. cause i think there alittle high and are generic measurement but thanks anyway.H194 with tailgate closed, ground to top of tailgate = 59.1”. Minus 1.3” for 2WD with air suspension at normal ride height = 57.8”
When is stops raining I will measure it for you.i have them spec"s but was looking for some real live measurement. cause i think there alittle high and are generic measurement but thanks anyway.
thank you very much. that is 1.5 inchs lower than spec sheet says 37.5. hope that holds true with the 2022 i have ordered. maybe can get some other people to chime in to compare. thanks againGot wet. LOL Height of the bed at the tailgate is 36 inches. Gravel driveway so might be a bit off but it will be close. By bed I am referring to the loading surface, not the bed rails. Rear wheel drive dually with air suspension.
End of the tailgate will be a bit higher. Also my truck my have setttled on the springs somewhat with a couple thousand miles. Can't wait to hook this monster fifth wheel to the truck in the fall. Taking it for a 1500 mile tow.thank you very much. that is 1.5 inchs lower than spec sheet says 37.5. hope that holds true with the 2022 i have ordered. maybe can get some other people to chime in to compare. thanks again
let me know how it goes and what you think of the truck. hoping to have ours by oct. have trip planned end of oct. have 43 ft landmark newportEnd of the tailgate will be a bit higher. Also my truck my have setttled on the springs somewhat with a couple thousand miles. Can't wait to hook this monster fifth wheel to the truck in the fall. Taking it for a 1500 mile tow.
I have a 40 foot Newmar Kountry Aire that weighs 21000. Should give her a good workout.let me know how it goes and what you think of the truck. hoping to have ours by oct. have trip planned end of oct. have 43 ft landmark newport
Would you know how wide the outside to outside of the DRW fenders are on your truck?I have a 40 foot Newmar Kountry Aire that weighs 21000. Should give her a good workout.
8ft almost exactly if i remember rightWould you know how wide the outside to outside of the DRW fenders are on your truck?
per ram truck 96.2 inchesWould you know how wide the outside to outside of the DRW fenders are on your truck?
Thank you so much.per ram truck 96.2 inches
