Battery Saver warning coming on
jkbrereton
I have a 2019 Power Wagon and the Battery Saver warning keeps coming up. Everything works fine and the volt meter always reads right in the middle. Has anyone had this issue?
I will get it looked at for the next oil change. Just was wondering if this was a known issue
Sent from my Pixel 2 XL using Tapatalk
I have a 2019 2500 Laramie and have this issue every winter. Usually on days near or below freezing and mostly when I remotely start the truck. The battery saver mode shuts off 12” infotainment system until truck is restarted. I have had the dealer look into it at least 3 times and they found no errors or low battery readings. Tech said they haven’t seen issue before. Frustrating but have been living with it so far.
