MCV
I've been stranded a dozen times with dead batteries, and I've given up on getting Stellantis to replace both defective-upon-delivery factory batteries. After weeks of diagnostics at multiple dealers, the only erratic parasitic draws we've identified are associated with the batteries. I reach the same conclusions with my overnight amperage draw tests. So I'm installing two new AGMs out-of-pocket, with the anticipation that will solve everything. However, my question is whether it is a solid idea to also install a battery isolator. I have dual alternators and dual batteries. I am NOT asking about trailer or accessory batteries, I'm referring to the two under-hood batteries to start the diesel. I recognize on cold startup, our diesels need the amperage from both batteries to run the grid heater, etc. It is my understanding that are battery isolation systems to handle that, by only allowing cross-flow when ignition is on. However, I don't understand how the dual alternators work, and whether any modifications I do in terms of installing a battery isolator will confuse the computer control of that second alternator. So two questions: 1) Is it a great idea to install a battery isolator so I can be certain to have at least one fully charged battery (which is sufficient to start my truck on a warm day), and 2) if so, is there a particular system that will work better?
I'm entirely open to someone telling me that I am being stupid, just replace the batteries and all will be fine. I may be overworking the problem, but I am tired of having a 100% dead truck. (So dead that FOB won't work, Lithium jump starters won't work, etc).
Background: I have the dual alternators (440 amp) as part of the snowplow prep package. However, I have no high amp devices; no winch, no snowplow. Basic stock Tradesman.
