Battery died. Truck in plant mode??
HDRAM405
What is plant mode. How do i get out of it.
2023 ram laramie diesel 2500
It’s a limited function mode on the trucks for shipping purposes, so the batteries don’t die between the time it leaves the plant and it’s delivered to the dealer
If plant mode is the same as ship mode then this might help.
Depending on your options you may not be able to manually exit it.
How many miles on the truck?
https://www.ramtrucks.com/BodyBuilder/service/Image?imageId=MtQrP%2FFqLY5r%2Fest8MtGjGgHzAHGUTU0WB3rWuqSY7YmQ2vEhuBWBNEjUV3DAnac%0A#:~:text=Typically%2C%20vehicles%20are%20removed%20from,sequence%20or%20“chicken%20dance.”
How did you get it IN that mode in the first place?
Is my dad‘s truck, he somehow killed the battery when it was parked in the garage, which means he left something on, which is weird because most of the electronic lights, and what not timeout. Anyways when he went to go use it, the battery was dead so we charged the battery back up and that was the display after he got everything charged up
Have you tried pulling the battery cables for 15 minutes?
That is so strange. I can’t imagine this would be a possible result of having to replace the batteries. At least I hope not!
