desert_wagon
Please post the solution if you do call them. This will be the set up I am going with...the LP9's are sitting in my garage waiting for the truck to show up. I was planning on just not wiring the low beam wire, but if there is a way I would do it.
Thanks for the infoMinor update: data sheets say [email protected], this is grossly incorrect. I measured 23 to 24 amps at 12.2volts on high beam and 9 amps at low beam. Used a calibrated fluke dc amp probe. Tested 2 sets using a stock harness "172" and my modified one.
Yea that was me asking, I could use a fuse tap, not thinking I like the idea of drilling a small hole in the fuseboxIn another thread someone posted that the clearance light fuse is F79 if that helps.
Do you have the front camera? Do those totally block it?
There are some molded-in holes between the rows of fuses in the fuse box. I was able to run 2 fusetaps and their wires through one hole, running wires out through the bottom of the fuse box. This provides "ign on" and "lights on" signals for my SwitchPro 9100, without any permanent mods to the OEM wiring or fuse panel.Yea that was me asking, I could use a fuse tap, not thinking I like the idea of drilling a small hole in the fusebox
gonna have to poke aroud a bit. thanks for the info on access holesThere are some molded-in holes between the rows of fuses in the fuse box. I was able to run 2 fusetaps and their wires through one hole, running wires out through the bottom of the fuse box. This provides "ign on" and "lights on" signals for my SwitchPro 9100, without any permanent mods to the OEM wiring or fuse panel.
What about the 360 camera stuff? Does it interfere with that too?Yes they do block it quite alot. You can see a sliver in the middle but that's about it. Enough the get an idea of how close you are.
just the front a bit, the rest is good. If there was an adapter to move it 6" out, that would fix it.What about the 360 camera stuff? Does it interfere with that too?
which fuse did you tap? for lights on? F79 by any chance?There are some molded-in holes between the rows of fuses in the fuse box. I was able to run 2 fusetaps and their wires through one hole, running wires out through the bottom of the fuse box. This provides "ign on" and "lights on" signals for my SwitchPro 9100, without any permanent mods to the OEM wiring or fuse panel.
cool, now to muck around a bit and get this setup...next on the agenda is an old school foot pedal switch for brights or to toggle between amber/clear/offYes! F79 for "Lights On" and F91 for "Ign On" power. Taps were tight to each other, but fit and work well.
