Banks or Insight CTS3
I went with Banks on the '25 as CTS3 wouldn't work correctly. It wouldn't allow my truck to go to sleep. Others have found since then that you have to turn off the CTS3 before shutting off the truck. I have the CTS3 in my Ford amd Banks in the Ram. I like the way I can have actual gauge looking parameters in the CTS3 vs just numbers on the Banks. I like the cleaner look of the Banks mount though.
You are correct, the regen percentage is a whole number without decimal point.
That’s one parameter that I just don’t see being “exact” enough to justify a decimal point anyways. A whole number is more than adequate to monitor where the DPF is sitting, IMO.
I went a couple years with whole numbers on regen % and then switched to a decimal, and the decimal was a lot nicer to watch… at least for me.
I suppose that my autism doesn’t reach that far.
Having a whole number is improvement enough alone over the factory “no numbers” needed filter reading lol
