22RAMAlazan
Hello all,
Thinking on getting Banks monster exhaust. Any Pros or Cons? Worth it? Thoughts?
Thank you VERY much for this information. To be honest, my end goal here is not really HP/TQ gains, I just want my engine to be as least stressed as possible or for it not to work as hard if not necessary. In my head, the less stressed an engine/transmission is on a daily basis it would last longer.Banks makes some quality products for sure. I'm not gonna sit here and pretend they are completely worthless.
That said, the real thing Banks has is fantastic marketing.
While there may be a technical benefit, I highly doubt you'll see any performance improvements from it alone. For example, on his site, he lists there is slightly less back-pressure at the turbo, claims of 9%. Great! Less back-pressure is what you want for sure, but if they have those numbers then surely they pulled them from a dyno run right? Why no hp/tq numbers? I'll tell you why, because it would be in the single or teens for hp numbers, and that would kill their marketing game. $650 for like 10hp?
Here is the results of Kory Willis testing the banks intake and exhaust on the L5P, which has more HP than the SO Cummins. It picked up a whopping 15hp. Will you feel 15hp? No, no way your butt dyno is so finely calibrated that you can tell ~4% increase in HP numbers. But will it sound better? Also no, or not really, but maybe a tiny bit if you pay real close attention? (Link to FB post from Kory: )
So, if the exhaust is making 4% improvement on an L5P, assume it's the same on the Cummins SO, that's a whopping 14hp. If you're looking for noticible power, better off saving up for a larger drop in and/or tuning.
But, it's your money, so do as you wish obviously. For what it's worth, I think all their products are very well designed and developed. I think their tips look great, and add some value for sure. I do plan to eventually swap in their intake elbow, mainly to remove the gridheater but also keep a heater coil. Longer term, once someone comes out with a compound kit, I'll prob look into that.
If you're solely looking for long term reliability, then you don't really need to look at anything except keeping up with maintenance. There are a lot of cures out there for problems that are functionally never likely to happen. The CP4 was a known killer, and it affected less than 4% of all Cummins trucks manufactured with it, admittedly within a really short timeframe, but still.Thank you VERY much for this information. To be honest, my end goal here is not really HP/TQ gains, I just want my engine to be as least stressed as possible or for it not to work as hard if not necessary. In my head, the less stressed an engine/transmission is on a daily basis it would last longer.
I did. Personally, not really super worried about the bolt. More cautious about the grid heater caking up. I don't let my truck idle much except startup, but it would be nice to remove the thing that can cake with soot, and removing the bolt is a benefit.Did you see the new $200 kit from BD Diesel?
Give it the beansWhen you all say "running the engine hard", what constitutes running it hard? I use it as a daily driver and tow a 12 foot dump trailer with about 2 tons of weight every once in awhile and a 2 horse gooseneck trailer maybe 1-2 times a month to go on a trail ride. Thats about it.
