Auxiliary Switches mounted above rear view mirror
Chrisburke
I am looking for options of auxiliary Switches that can be mounted above the rear view mirror in an 2015 ram 3500. I need them to be in an toggle switch form like in the ford super duty’s. I am an DIYer so I do not care about an plug and play function. I have done my research and nothing so far. Any opinions and comments appreciated.
There's a thread over on 5thgenrams using some aftermarket (Switch Pro's?) and a 3D printed housing.
You could also easily mount the Trigger remote control switches. https://triggercontroller.com/
I have a Trigger4 plus I bought used and never installed if you're interested, It's missing the factory magnetic base which wouldn't be needed if you're mounting it. Make you a good deal on it.
Missing this part:
I just installed the factory aux switch panel in the center stack and the fuse/relay box from airdelete in my 2018. Using it to control rear spot, rear fog and DC 2 DC charger.
Very clean install.
