We have three of these working now. The "straw" out of the tank is a 3/8" HDPE male hose barb/nipple, so we put 3/8" heavy duty fuel line on it with a stainless steel hose clamp. We then run it over to the driver side rear underbody tool box. Don't run it to the rear driver side box! Being above the exhaust pipe, we measured it at 130F in the box. We plumbed it into the box with a cable gland fitting, then into a Seaflow pump (SFGP1-032-003-01). We run 3/8" x 15' of fuel line to a 3/4" Fill-Rite nozzle on a swivel. Just neck it down with a 3/4" MNPT to 3/8" Hose Barb to connect them. We are in the process of adding a Reelcraft Model# B3620 OLP to manage the line instead of having a 15' goat rope stuffed into the box. The reel just fits into the underbody box. Ultimately, you are only going to get 3-4GPM since the connection is only 3/8". For us this is fine, since it only takes 2-3 minutes to refuel a generator. Also, we have a deep cycle battery in the underbody box to power our lift/hoist system, so we just connected the pump to the battery with an On/Off toggle switch in the box for the pump, so you will need to figure out where to get 12VDC power. Hope this helps.
