Haleme
I am adding Aux Switches to my 2018 2500. It did not come with the Upfitters prep, Snow Chief or any options I can see to support Aux switches.
That said, I have purchased the correct switch panel to replace my existing panel and the kit from AirDelete.com to complete the job.
My question on the wiring is on what I found from the factory when I started to do the install.
The factory wiring already has the 5 wires built in for Aux switches.
The colors perfectly match the Upfitters Schematic for my truck, so I reason these are the wires that would be used to go to the Aux relay box if it was built from the factory.
I also found I have the blunt cut wires under the PDC.
So, the question is, where do these 5 wires in the dash terminate?
