Aux Switch Upgrade
dloroff32
I have a 2020 Ram 2500 Tradesman. I currently do not have the Aux switch panel or wiring and was looking to install. What kit is used and where can I find said kit?
There are a lot of threads where this has been discussed. The first one below probably has the most information and here are two others not as specific to the question as the first one though. There are more also but hopefully these will get it for you.
Yeah I checked those 3 out. None of them give a Part Number for Aux switch panel or the wire harness for it. My truck has the PDC box and looking for the switches and the wires needed. Trying to keep a factory clean look but getting someone able to give useful part numbers needed is hard to come by.
OK. Sorry can't help with that. Mine were ordered with the truck so all I know is from those threads and my own experience connecting them up. I think I have seen the part number for the wiring harness but then I also vaguely remember someone saying you cannot get that harness. So not sure. Someone here will likely know though.
The very first post in the very first linked thread has a link to the switch part number chart.
Also discussed in the threads is you would have to replace the entire left dash wiring harness. Basically the wiring is going to be custom.
There's a few sources listed in those threads for members that can build you the harness with instructions for either solution but I'm not going to read them all for you.
If you want to 100% DIY, then you're going to have to read up.
