Aux switch prep
eljeffy
I have the aux switch prep but no switches. I was told by the dealer that with tech plus package with the trailer turn assist knob the switches can't be both added but comes prepped. How does the aux switch prep work, Am I able to make any use of the prep if I don't have abilitiy to add the ram switches? should I just buy a switch pros and ignore the prep wiring all together
I have the same question. Have the trailer steering, would rather have the switches, but that’s what I got…
The box under the hood is there, but no fuses or connection or wires thru the firewall, as far as I can see?
I was thinking of getting the gas version of the trailer control, it has 4 Aux Switches, plus Front and rear park sense switches.
Then move the exhaust brake, tow/haul, and traction control to the space on the 4WD selector.
Where they should have been all along!!! There’s lots of room on the selector.
you figure this out.. just picked up a 25 with the prep switch wiring. Online says you just need to order the switches and plug them in.. cant seem to find the part though.. 25s are kinda new so maybe thats why... curious if you got yours set up
I ended up buying a switch pro and just wiring it in to the left lower or steering wheel
