Are these plugs for bed lights?
Dirtstiff
Oregoneifornia
I'm trying to add bed lights.
Can anyone tell if either or both plugs are for the bed light harness?
If you don’t have bed lights im pretty sure you have to go right to the BCM but im not 100%
Thanks for the video. I had seen it and wondered if his harness could be different from mine. I've got 3 plugs that look like they could receive the light plugs, but are not all together.
I'll have the kit tomorrow and will likely wire it direct to the fuse box with a switch in the oem cover in the bed..
Thanks
ThanksView attachment 84220View attachment 84221
Those look like DRVM and TTPMS plugs.
When I added the bed lights to my 2018 it was P&P. The wires were populated in the bed sides, not the rear bumper. The OEM kit did come with the wires to run to the BCM so some models aren’t P&P.
Got fused power routed to a rocker switch in the bed at the oem switch location. Should be quick work once I receive the light kit.
Thanks
