KnuckleHead
Hey Everyone,
Finally got my hands on a ARB twin compressor. Doing the install today and I thought I had it all figured out (foreshadowing). I was under the impression that I just needed to install the power/ground to the battery and then use the supplied smaller harness and use the purple as + and the black as - and put those into the SPOD switch connectors inside the SPOD box. The others were not used. This is just for the compressor, no lockers or anything (PW already has those
). But, as you may have guess by now, the compressor does not turn on when I press the button on my SPOD.
Has anyone done this combo? It is very possible one of my connections is not solid, but I thought I would check to confirm that is all I need to do for the wiring before I start looking at connections.
Thanks
Thanks
